2023-04-26 07:52 PM - last edited on 2024-02-04 11:43 PM by willzhou
I recently designed a wireless transmitter utilizing STWBC86, however, I have encountered a boot issue due to an empty FTP memory. I have been searching for firmware and a GUI to upload the firmware into the FTP, but have not had any success yet.
Has anyone encountered a similar issue or successfully designed and tested a wireless transmitter using STWBC86? Any suggestions or advice would be greatly appreciated.
2024-02-04 11:42 PM
Hi
You can find WPSTUDIO tool and tx fw in this link
https://github.com/STwirelesscharger/STSW-WPSTUDIO
STWBC86 fw is
https://github.com/STwirelesscharger/STSW-WPSTUDIO/tree/main/STSW-WBC86FWBPP
2023-11-14 11:46 PM
I do have a similar Problem.
When using the WPSTUDIO (Version1.8.4) i cannot connect to the STWBC86 because the IDs somehow don`t match an i therefore cannot program it.
Did you find a solution for your Problem?
2024-02-04 11:42 PM
Hi
STWBC86 fw is
