2023-12-11 1:09 PM
I have tried every possible option to get the discovery kit working. I am not satisfied with your technical support. How do I return item for a refund?
2023-12-11 1:33 PM
Get an RMA from your distributor? Or ST if you purchased directly, use the same points of contact.
Submit a support ticket https://www.st.com/content/st_com/en/support/support-home.html
