2015-09-10 12:57 AM
Enrico,
There seems to be quite complex patented algo with about half a dozen adjustable parameters. I have seen one of your comments elsewhere that suggested some configs can make the circuit unstable and oscillatory. The data sheet explains the basic operation but this is not sufficient to engineer a proper configuration. Suck-it-and-see , from an engineering perspective ... sucks. Is there any guidance on how to correctly parametrise these L64xx family chips? Thanks.
