EVALKIT-ROBOT-1 Problem
Problem Description:
At power on the motor do not initialize to find the zero signal of the encoder.
The red led is on, not blinking
Attached the wired motor
Thank you for reply
2020-07-08 2:53 AM
2020-07-10 7:52 AM
Hi @RDa F.1 welcome to ST Community.
I think your problem could be related to a bug we found in the previous code version.
You can download the new revision of STSW-ROBOT-1 and check if the problem is solved.
Let me know if it is ok.
2020-07-10 7:52 AM
2020-07-10 8:21 AM
thank you for the mail.
Following the user manual:
than we have power up the system *without loading any software*:
at this point the motor _do not show any initialization_.
Up to this point we have not use any software, we have use the eval kit
as-is, as from the user manual.
In the user manual there are not any tips about "load the software
before power on"
So I think that the problem it is inside the firmware of the control board.
Waiting for you kind reply
Best Ragards
2020-07-10 9:02 AM
Hi @RDa F.1 the know bug is in the pre-loaded firmware.
The STSW-ROBOT-1 is the firmware example of the EVALKIT-ROBOT-1 evaluation kit.
The main.c code was modified to solve the initialization procedure.
You can update the firmware using a SWD programmer/debugger supporting the STM32F0 family, like the STLINK-V3 from STMicroelectronics.
2020-07-14 3:51 AM
to do some evaluations on potential applications we cannot reprogram the system.
we have bought the eval kit as free of bug
thank you
2020-07-15 12:00 AM
I can suggest a workaround to solve this FW issue of initialization procedure.
Try to power-up the board and after RESET the device.
Please let me know if you are able to use the kit for your evaluations.
2020-11-19 9:22 AM
Cristiana,
I am having the same issue.
The red LED blinks meaning the system gets into fault mode as in line 135 of code: if (MC_GetOccurredFaultsMotor1() != 0)
Thank you in advance
EDIT: Problem Solved. I was having issues with the power supply. Once I fixed it and provided the motor with at least 30V power was asserted and the system ran well.
