disable power-on reset(POR) and brown-out reset(BOR)
Posted on July 27, 2010 at 09:52disable power-on reset(POR) and brown-out reset(BOR)
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Posted on June 03, 2010 at 11:55Hi there, I spent the entire day yesterday trying yet again to get the sample code (UM0884) to compile. For some reason I am struggling to understand the code that has been written as a worked example, there seems to ...
Posted on July 13, 2010 at 09:29BeCAN off-bus
Posted on July 12, 2010 at 13:49Hi We where using ST10F272 and we are now migrating to ST10F276. same code is not working for Port 8.1 and port 8.3 . please advise.
Posted on May 12, 2010 at 17:27Dear friends,I'd like to know whether someone has assembled and tested the hyperterminal application example on STM8 discovery demo board, using the ST232 driver IC.I've done that but the hyperterminal doesn't communic...
Posted on July 03, 2010 at 02:10Just got a Discovery kit, downloaded the sttoolsset.exe. Ran the exe, hit the next button on the wiz, the package starts to unpack. Than an error msg pops up saying the exe is corrupt. Tried several down loads and two...
Posted on July 07, 2010 at 12:28I am developing an application with STR750 and I use the watchdog timer in watchdog mode. I have to fix a watchdog issue and find where my application code in some working conditions stops refreshing the watchdog time...
Posted on February 14, 2006 at 15:01ST MCU help
Posted on August 21, 2009 at 15:11ST10 Flasher interface & Connection. #st10-dump
Posted on July 06, 2010 at 15:53Hello, I'm trying to dim a LED with the touch sensor on the STM8S Discovery board. After a touch the LED begins to dim until it's dark, but it should stop dimming, if I take my finger away again. This action is not r...
