Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
I/O PORTS
Posted on November 06, 2010 at 23:34Dear, I need your help about...I'm programing by asm, I need to use the outputs ports to control lcd numbers. i don't know how to do to prepair the port to do output port. I don't understand the port configuration...
Beep in UM_0884
Posted on November 01, 2010 at 20:48I am using UM_0884 to learn more about STM8S-discovery and everything wa going good until I connected the beeper as shown on page 6/23.  The problem is it doesn't work. hyperterminal.c seems to work and it calls b...
carnett1 by Associate II
  • 1499 Views
  • 7 replies
Availability, when?
Posted on October 18, 2010 at 12:32Hello, Does anybody know when the new STM8L-Discovery will be really available? both digikey and farnell don't have it in stock yet. Giovanni ---http://chibios.sourceforge.net/
Programmer wanted, microchip and visual
Posted on October 26, 2010 at 05:38Hello, My name is Aaron. I am looking to hire a programmer. Qualifications are as followed. 1. Must be able to program a STM8S (more info here http://www.st.com/mcu/contentid-130-113-STM8S_DISCOVERY.html) (For our ...
kiyoukan by Associate II
  • 1383 Views
  • 6 replies
RS232 STM8S-discovery
Posted on October 25, 2010 at 22:23I have tried using0UM)884.  If I have the rs2323 disconnected from the PC i get an error.  I connect the rs232 cable it runs, but I don't get anything on my computer monitor. I put a breakpoint after the menu is su...
  • 1377 Views
  • 4 replies
ST72F561 re programming
Posted on October 11, 2010 at 13:32To debug / Flash the ST72F561-controller - I understand that either we should have the STICK from ST or similar one from Raisonance.  We need to purchase a compiler and then STVP7 will help me for programming.  Is ...
vnadgir by Associate
  • 753 Views
  • 0 replies
how to disable IWDG during run time
Posted on October 01, 2010 at 07:59Hi all, i need to disable the independent watchdog during runtime. (after it was started once). what is the way for this. also i am using LSI as my MASTER clock source. #iwdg
finding STM8S-discovery.ht
Posted on September 27, 2010 at 19:39I want to use the RS232 example so I can figure out how to give variables to the kit and read the response but I don't have STM8S-discovery.ht.  Where do I get it? charles #cosmic #rs232
  • 1173 Views
3 PWM in stm8s
Posted on September 26, 2010 at 12:39Hello All  i need use 3 pwm  by user timer1, timer2, timer3 by config TIM1_PWMIConfig(); TIM2_PWMIConfig(); TIM3_PWMIConfig(); How to config? i use stm8s-discovery #tim1 #pwm #stm8s #tim2 #timer #tim3
uthenb by Associate II
  • 1108 Views
  • 0 replies
Desoldering the sockets
Posted on August 28, 2010 at 12:18I'd like to make the board more useful by desoldering the header plugs on the board and replacing them with sockets I can plug wires directly into. I've tried using braid and my solder sucker but neither is working...
