stm8s003f3 does not answer
Posted on April 09, 2017 at 08:00Hello every bodyI am new in stm8s003f3 i use iar code limited and stlink/v2I read error swim 30006 and i can't correct it Please help me#swim-error
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Posted on April 06, 2017 at 16:20Hi. I change memory model and libraries for code larger than 64K. The error receive after linking: #error clnk Debug\canli.lkf:1 symbol __stext not defined (Debug\stm8l_stl_startup.o ) The command: 'clnk -l'C:\Progra...
Posted on April 06, 2017 at 17:13ST product selector doesn't have a selection for JTAG port. What bi-directional ST Micro TVS would be optimal for a JTAG port to use for ESD protection? Looking for a part number please. ST improving the website t...
Posted on April 04, 2017 at 12:46Hello,im quite new to the STM32 ecosystem and i'm looking for a board to start my IoT project.I found the SWPF01SA module but it is not clear if it is what i want (can't fine much on GPIO).I assume it doesn't have an...
Posted on March 31, 2017 at 14:45Hello Everyone.. I have come across ST710F microcontroller in one of our old designs. I tried to find the information about this microcontroller but I have not found any information. Is this part obsolete? If it is o...
Posted on March 28, 2017 at 12:35Hello every body. I want to know what is the best way to test assembly program?? use simulator in Stvd or .......... ???
Posted on March 21, 2017 at 13:28&sharpinclude <iostm8s003f3.h>&sharpinclude <intrinsics.h>int main(){ // // Initialise Port D. // PD_ODR = 0; // All pins are turned off. PD_DDR_DDR4 = 1; // Port D, bit 4 is output. PD_CR1_C14 = 1; // Pin is set to ...
Posted on March 25, 2017 at 10:03#include 'Filter.h'#define Samples 3#include <math.h>#include <stdlib.h>extern unsigned long int data;long int Result_Previous,Average,;unsigned char Stable;void FIR_Filter(unsigned long int Clean){ static unsigne...
Posted on March 25, 2017 at 09:38Hello. I want compile a simple program that is :stm8/segment 'rom'PD_ODR EQU $500FPD_DDR EQU $5011PD_CR1 EQU $5012;///////////////////////bset PD_DDR,#6bset PD_CR1,#6loop2bset pd_odr,#6bres pd_odr,#6jp loop2endwhen I...
Posted on March 24, 2017 at 15:03Smart Transformer Selector and eDesignSuiteUsers of https://my.st.com/analogsimulator/ can now integrate Würth Elektronik Midcom’s transformers in their designs.Thanks to a partnership with Würth Electronik Midcom, w...
