Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
jump to main user application failed
Posted on May 30, 2018 at 11:07Hi,I am working on a custom bootloader code for the STM8S207.using the standard jump routings that are used in the example code AN2659.the example code work fine, when i try to change location from 0xA000 to 0x11000 of...
Unable to Build project
Posted on May 25, 2018 at 10:22I am new to ST.I downloaded and installed STVD and Cosmic Free Compiler on Windows 7I made a project and trying to build I get the following error message.----------- Project helloworld - STM8 Cosmic - Configuration De...
Failed to start GDB
Posted on May 23, 2018 at 07:12I have been using ST visual develop version 4.3.11 with cosmic compiler, I started getting some unknown errors regarding some GDB settings as shown in the files attached. I even tried uninstalling and reinstalling Cosm...
Project Firmware Compilation
Posted on May 22, 2018 at 16:26Good day everyone. I require professional code to be compiled for a project based on an STM8S003 that interfaces to an accelerometer and SIGFOX transceiver. Please email mailto:electronicdesignpower@gmail.com if you ar...
