Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Help with power supply of STM8L152C6T6 MCU
Hello,I'm designing a PCB using the STM8L152C6T6 communicating with an M24LR04E-RMC6T via the I2C protocol. Currently, I'm struggling to understand the power supply schema. According to the datasheet, VDD1, VDD2, and VDDA pins must be connected to an...
L9733 Hardware integration and SPI access
Hi,I designed a board integrating a High Side L9733.I try to communicate with the switch through SPI but I miss some informations.1- Can you confirm that we can use a 1.8V SoC as master?I fixed VDO to 1.8V. I didn't find nominal range for VDO. (only ...
rmt37 by Associate
  • 1052 Views
  • 0 replies
Is VNQ7140AJTR discontinued?
I'm trying to get a hold of 500 units of VNQ7140AJTR and I've been unable to find any in stock at any distributor. I placed an order with Digikey about a month ago and it has been on back order since then. They are not able to give me an expected del...
KGreg by Associate
  • 703 Views
  • 0 replies
hello sir, problem with debug - st-link
i installed the latest stvd, in windows 10.i try a program, for the discovery board., its ok with compling, and build, but when i want to debug, it say " connection error (usb:/usb):gdi-error (40201)can't access configuration databasei can read out t...
Sensing +12 signal input using ST microcontroller
I am using STM8AF5288 microcontroller in one of my project. Is it possible to sense direct +12 signal input by port pins? I am using current limit resistor in Input.All the port pins in ST microcontroller have clamping diodes.Will i able to sense +12...
leojo by Associate
  • 908 Views
  • 0 replies
