Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
How can i configure pins "PD6 and PD5" of controller "STM8S103F3" in low state (voltage level 0) in "input mode" .
Hi All,I am using "STM8S103F3" controller. When i am reading the voltage levels on the pins "PD6 and PD5" on startup (no external connection), using "IDR" registers, it is showing voltage level as 1 (5v). I want to know, how i can set the voltage lev...
HTiwa.11 by Associate II
  • 1414 Views
  • 1 replies
Trouble with floating point conversions
Hi. If I create a C floating point number (ab) and set its value equal to a 32 bit integer (or a constant), the integer and the float are very different, at least as reported by the STVD debugger watch window. Normally, I'd expect to see a clean con...
STM8 community forum broken?
When I look at the STM8 community forum (https://community.st.com/s/group/0F90X000000AXt8SAG/stm8-mcus), I see no content.I tried with both Firefox 68.5.0esr and Chromium 79.0.3945.130.But I know there should be content: I posted something, and both ...
