Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! Error Amplifier Compensation Network Design
Hi, I'm using the converter Viper06 in my power supply board project. I'm having some difficulties to design the compensation network of the error amplifier. Could someone please tell me how to do this o share some documents that explains how t...
FLM.1 by Associate II
  • 2101 Views
Hi, Is it possible to have any mathematical dependencies, even approximate, between EEPROM FIT values and supply voltage? Thank you.
This might be a very basic question: EEPROM FIT values are based on standard single value of Ea = 0.7 eV. Is it irrelevant to supply voltage? I mean using lower supply for wide range device might reduce FIT values. Are any mathematical dependencies, ...
MLiou.1 by Associate II
  • 988 Views
  • 1 replies
Hi, Does FIT of 2.4@90% 55°C/ ea=0.7 applies to higher reliability EEPROMs M24512-DRD3TP and M93C56-RDW3TP or they have has different FIT? Thank you!
Hi, I just got an answer for reliability of general parts EEPROMs M24512-DRD and M93C56-RDW. Thank you! Does 2.4@90% 55°C/ ea=0.7 applies to both _3TP and _6TP of M24512-DRD and M93C56-RDW, or M24512-DRD3TP and M93C56-RDW3TP has different FIT?
  • 1135 Views
  • 1 replies
how to establish a communication with M24c32-R?
I am trying to communicate M24C32-R with master but for some reason i could not able to !! It appears to me it might be hardware issue. I have connected E0,E1,E2 to ground , Vcc to 3.3V, WC to ground, I have pulled up SCL and SDA to 3.3V with 10K oh...
Apill by Senior
  • 2629 Views
  • 5 replies
