Which board has....
zhenhua0197
Posted on November 28, 2008 at 10:42
Which board has....
3 REPLIES 3
zhenhua0197
Posted on May 17, 2011 at 09:56
Hi all, as a student getting started to learn embedded (Linux) system, I'm looking for a nice development board, which embodies a 32bit ARM9 processor and some useful connection (USB, 2 or 3 serial, ethernet, camera...). For me as a beginner, I need it to be ready to run and inexpensive (<=$300), pre-configured tool chain and necessary binaries, example projects included.
better would it be if it has been attached with a LCD
Thanks in advance for any information that would be helpful.
jon2399
You may would like to check the
http://www.developmentboard.net/index.php/productdetail/Development+boards/ARM9/SAMSUNG/S3C2440/MINI2440+with+LCD
from
ARM920T CPU
64M SDRAM+64M NAND FLASH+2M Nor Flash
USB HOST and device
3 serial ports
SD card slot
3.5'' TFT LCD
Price=€200= about $251
seems a great board, I have bought it 2 days ago and will get it soon :) :D
dhoyen
hi,
I m not an expert about embedded linux, but seems need a external memory controler, with ''huge'' quantity (in comparaison to the STR9 embedded 96K of RAM). Same idea with flash.
Take a look with Atmel, they make some ARM9 at 180-200 Mhz (i forget the name of these device), really well supported by linux and the community and with plenty of documentation as / how tu use GCC, linux...
Good luck.
