2006-02-22 05:23 AM
2005-09-16 02:50 PM
I am trying to reverse engineer an existing ST6 application. I have the .hex file but no source files. Are there any free or cheap tools that can decode the .hex file and generate the assembly instructions?
2005-09-18 09:43 PM
I wrote a plugin for IDA (http://www.datarescue.com), it is available at
other solutions include using the ceibo kit. its been a while since i have ventured down the st6 route. Regards sjo2005-09-21 09:13 AM
I took a quick look at the plug in files that you refered me to, but I don't know how to use a plugin. Does IDA Pro have a simple mechanism for activating and using the a group of files such as these?
Thanks for your help in advance. Gary2005-09-21 11:40 PM
Just place the plugin in the ida directory and it will be found.
Regards sjo2006-02-22 05:23 AM
Hi there
I was reading this forum and I found this issue, and I am now in the same problem. Could you tell me, how about decompiling the hex file, and if was successful. I’m trying to do the same thing but I have problems. please send message tomailto:curuchupa@hotmail.com
RegardsQuote:
On 17-09-2005 at 03:20, Anonymous wrote: I am trying to reverse engineer an existing ST6 application. I have the .hex file but no source files. Are there any free or cheap tools that can decode the .hex file and generate the assembly instructions?
