2007-07-31 10:40 PM
REVA w/STR750 daughterboard manual
2007-07-23 12:01 PM
I recently received a REVA board and STR750 kit (STR750-SK/RAIS). The board quickstart example works fine, but I been unable to locate the manual for the STR750 daughter board anywhere on the web or from the unpacked docs from the included CD. Also, the only example program was a simple echo of switches to LEDs, so I have no idea how the ports map from the STR750 to the REVA main board.
Does this manual exist, and where can I download it? Jack Peacock2007-07-30 01:18 AM
In the Starter kit a CD is included ,where you can find the setup.exe of RIDE (IDE with GNU compiler). Install RIDE, Go to START->ALL programs->Raisonance kit 6.1->RIDE IDE then go to help->PDF->STRx tools->Reva daughter board for STRx You'll find all then necessary.8-) Regards, MBS [ This message was edited by: MBS on 30-07-2007 13:49 ]2007-07-30 05:35 AM
No such luck. It shows STR711 and STR730, but no STR750 daughterboard. No STR750 PDF on the Raisonance web site either. Does it exist?
I did check that the RIDE kit was the latest build from the Raisonance website, including P1 and P2 patches. [ This message was edited by: JakBird on 31-07-2007 02:11 ]2007-07-31 10:40 PM
Quote:
It shows STR711 and STR730, but no STR750 daughter board
I think this should be what you're looking for?8-) Regards, MBS [ This message was edited by: MBS on 01-08-2007 11:11 ] ________________ Attachments : REva_User_Guide_STR.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtPM&d=%2Fa%2F0X0000000aPZ%2FFL053d40fHEoa20_qwKZNhP.XL2ltkdmJ4Tq.IPuhTw&asPdf=false
