2005-06-12 08:59 PM
New FreeRTOS release supports STR71x
2005-06-12 08:59 PM
FreeRTOS V3.1.0 is now available for download and contains a port and sample application for the STR71x.
Source code and documentation is available from . FreeRTOS is an open source mini real time scheduler. The sample application is preconfigured to run on the IAR KickStart kit using the IAR compiler. Future releases will directly include support for other compilers. In the mean time other existing ARM7 ports for Rowley CrossWorks, Keil and GCC can easily be modified for the STR71x. [ This message was edited by: FreeRTOS on 13-06-2005 09:32 ]
