InDart STX, Breakpoints real time mode problem
brian4
Posted on June 01, 2004 at 08:12
3 REPLIES 3
brian4
Posted on June 01, 2004 at 07:29
Using an InDart-STX with a St72324 running ASM code
If I place a break point in the code then the software does not run in “real time�.
Are there any tricks I can use so that I can run my code in real time and break at a specific point.
Many thanks
sjo
Posted on June 01, 2004 at 08:03
Use a trap instruction, this is documented in the indart user manual.
sjo
brian4
Many thanks, will try that.
Knew there was an answer
