adib
IAP question/problem
  • June 1, 2004
  • 3 replies
  • 627 views
Posted on June 01, 2004 at 09:45
adib
adibAuthor
Posted on May 26, 2004 at 15:33
I want to use the compilation generated SREC file to do field IAP.
In the SREC file there are address that reside in sector 0 boundary.
Is it safe to ''write'' to sector 0 addresses in IAP? or should I ''filter'' the SREC for address that reside in sector 0?
dominique2
Visitor II
June 1, 2004
Posted on June 01, 2004 at 09:18
You cannot write the sector 0 in IAP: it is write protected.
Dominique
sjo
If you look at the Flashbash (www.spen-soft.co.uk) source code you will see an example of filtering out sector0 from an s19 file to support IAP.
eg. addresses 0xFC00-0xFFFF are ignored from the s19 file.
sjo
