Illegal opcode
luter
Posted on March 01, 2006 at 08:50
Illegal opcode
12 REPLIES 12
luter
Posted on February 24, 2006 at 06:31
Hello.
I wanna force micro to make selfreset by executing of illegal opcode. Can anybody suggest me any illegal opcodes?
Tnx.
luter
Posted on February 24, 2006 at 07:06
I found :-]
0x31, 0x32, 0x3b, 0x41, 0x65, 0x72
right?
wolfgang2399
Posted on February 24, 2006 at 08:03
Hi Luter,
to reset my µC I use
- starving the watchdog in an endless loop or
- setting WDGCR to 0xFF followed by 0x80 (clearing T6).
You can also use the HALT instruction with WDG is activated (but: see chapter 11.1.4.1).
WoRo
luter
Posted on February 24, 2006 at 09:36
To woro.
I need to distinguish between wdg reset and my own reset when micro starts up. illegal opcode execution does not set wgd reset flag in SICSR.
What do u mean under ''chapter 11.1.4.1'' ? What kind of an is it?
wolfgang2399
Posted on February 28, 2006 at 05:09
Sorry I forgot about to say: I refere to the main document - the datasheet.
I wouldn't take an illegal opcode to restart because you never can be sure they will abide this instruction. They might change it at any time without notice.
Alternation: Fix a memory cell e.g. with 0xA5 before triggering the watchdog and read this before initialising your memory.
WoRo
luter
Posted on February 28, 2006 at 08:16
Quote:
I am still not getting you. What type of datasheet do u mean?
WoRo
Tnx for advice, but my micro st7mc2 has flash memory only, and it is a bit complex to store some byte there.
wolfgang2399
Posted on February 28, 2006 at 10:08
Hi Luter,
sorry I supposed a ST7Lite2x but with your micro you must read:
But: see chapter 10.1.4 Using Halt Mode with the WDG.
What I mean with the memory cell is that you can determine any unused RAM cell, set it to a special value e.g. 0xA5 and then force a watchdog reset. Immediately after a reset you should fetch the value and reset the RAM memory to a base value e.g. 0x00. Thus checking the fetched value you can recognise whether you have passed a tagged (0xA5) watchdog reset or not (0x00).
WoRo
luter
Posted on February 28, 2006 at 11:16
Now, I understand your idea. It is pretty good. But are u sure that reset doesn't disturb ram memory? As far as i know the content of ram memory is undefined after reset. Is anywhere notice about memory state after reset? I would be very appreciated if u give me a link.
luca239955_st
Posted on March 01, 2006 at 03:46
Be careful if you do that (use a special ram location as the flag for the type of reset) in C, as the standard startup code will clear your flag before you have a chance to test it; you will have to use a special version (customized by yourself) of the startup code.
Regards,
Luca
