enable the gpio(atlas)
eliahu
Posted on July 01, 2003 at 13:08
eliahu
Posted on July 01, 2003 at 08:57
hi all
In order to access the GPIO i need to access register 0xCF8 to enable the GPIO
As you know register 0xCF8 is 32 bit register
How should I access register 0xCF8 (I am using OUT command that can access 8 bit data) ?
thierry239955_st
Posted on July 01, 2003 at 12:15
It is not possible to split 32 bits access in 0xcf8 into a series of 8 bits access and your OUT command is unusable in this case.
You need a true 32 bits I/O access.
Which compiler are you using? There is probably ways to manage 32 bits I/O, maybe through in-line assembly?
Farfalla
eliahu
Quote:
hii
i using debug of dos6.22
and the command is (out dx,al)
how can I do with debug
