Compiler bug 4.5.5
rraval
Posted on September 12, 2007 at 07:30
Compiler bug 4.5.5
rraval
Posted on September 10, 2007 at 12:58
Hi There,
Can anyone came across this problem ?
Here is my problem:
I want to locate my function pointer array to code memory area. Here is how my code looks like:
void (* const Fptr[GRIP_MENUS])(void) = {
CheckGHome,
CheckGBandp,
CheckGPNap,
CheckGripMax,
CheckGRHome,
CheckFingerC,
CheckFingerC,
CheckSpread,
CheckWrap,
BandClicks,
NapkinClicks,
TopClicks,
NULL
As per my knowledge, when you have declared a variable .const it should go to 0xc000 to 0xffff segment. ( I am using COSMIC compiler 4.5.5 and my processor is ST72621)
Instead it generates this error ....
#error clnk Debug\diagnosis.lkf:1 bad address (0x1f5) for zero page symbol _Text
>>This was generated by V4.5.5
>> PLEASE NOTE THAT THE SAME CODE HAS DESIRED EFFECT WITH REV 4.2e of compiler. THE NEW REV has some problems identifying function pointers with .const qualifiers.
Any ideas ?
luca239955_st
as I explained directly to you, the problem comes from the code, where the same variable is declared @near once and @tiny (implicitely) in another file. The old compiler was less strict for this kind of check.
Luca (Cosmic)
