Use case: a pressure sensor which acts as an altimeter. At a place where there is a wide season change,does the LPS27HHTW provide the accuracy as mentioned in the Data sheet?My use case has critical implications and need an accuracy of about +1m (.12hPa).
Options
2022-02-14 2:47 AM
Does it also give the mentioned accuracy during weather changes? (Use case is set up in Europe.)
Labels:
Environmental Sensors
1 REPLY 1
Options
2022-02-14 9:10 AM
The datasheet only carries typical values, so no accuracy is guaranteed at all...
