LSM6DSO Pedometer
MasCreyt21
Hi BenG142, I'm trying to develop a pedometer application using the LSM6DSOX sensor, but I haven't been successful. Could you share your project files with me? I'd like to know which registers you used.
BenG142
Hi @MasCreyt21 ,
Without more information on where you've been unsuccessful, I will try to explain all steps.
So, assuming you've had positive communications with the IC (read/write registers, etc):
1. Start by setting up the Performance/ Power Mode you want:
        case XL_Power_Mode_ODR::Mode_High_Performance_6_66_kHz:
            WriteRegisterBitRange(LSM6DSOX_CTRL1_XL, 7, 4, 0b1010 );
            WriteRegisterBit ( LSM6DSOX_CTRL5_C, 7, false );            //XL_ULP_Enable
            WriteRegisterBit ( LSM6DSOX_CTRL6_C, 4, false );            //XL_HM_Mode
            break;
2. Set up FIFO:
void LSM6DSOX_::setFifo_Steps(){
    WriteRegister   ( LSM6DSOX_FUNC_CFG_ACCESS, 0x80 );            //Open Embedded Functions
    WriteRegisterBit( LSM6DSOX_EMB_FUNC_EN_A, 3, true );           //Enable Pedometer sensor in Adv Func
    WriteRegister   ( LSM6DSOX_EMB_FUNC_EN_B, 0x10);               //Enable false positive rejection
    WriteRegisterBit( LSM6DSOX_EMB_FUNC_FIFO_CFG, 6, true );       //Enable Step Counter Batching
    WriteRegister   ( LSM6DSOX_FUNC_CFG_ACCESS, 0x00);             //Close Embedded Functions
    WriteRegisterBitRange( LSM6DSOX_FIFO_CTRL4, 2, 0, 0b001 );  //set FIFO Mode
3. Read FIFO Registers:
  uint8_t reg1 = LSM6DSOX.ReadRegister(LSM6DSOX_FIFO_STATUS1);
  Serial.print("FIFO Status 1: ");
  Serial.println( reg1 );
  uint8_t reg2 = LSM6DSOX.ReadRegister(LSM6DSOX_FIFO_STATUS2);
  Serial.print("FIFO Status 2: ");
  Serial.println( reg2 );
4.  Clear FIFO at the end:
void LSM6DSOX_::setFifo_Clear(){
    WriteRegisterBitRange( LSM6DSOX_FIFO_CTRL4, 2, 0, 0b000);
Sadly not able to share the project, but hopefully this helps.
Cheers,
Ben
Screenshot from the closed thread mentioned by @Andrew Neil (Credit to @Federica Bossi) :
3 REPLIES 3
Andrew Neil
Evangelist III
@MasCreyt21 wrote:
Hi BenG142
@BenG142 's thread was closed over a year ago:
https://community.st.com/t5/mems-sensors/lsm6dso-fifo-pedometer/td-p/61470
So tell us what you did, and why you consider that "unsuccessful"
Did you follow the steps give by Ben and @Federica Bossi in the previous thread?
Please see the Posting Tips:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
BenG142
Hi @MasCreyt21 ,
            break;
2. Set up FIFO:
Cheers,
Ben
@BenG142
Thank you for your help, BenG142. Thanks to you, I solved my problem, and the LSM6DSOX is working as I wanted.
