2024-08-12 6:37 AM - last edited on 2024-08-12 7:25 AM by Andrew Neil
Hi BenG142, I'm trying to develop a pedometer application using the LSM6DSOX sensor, but I haven't been successful. Could you share your project files with me? I'd like to know which registers you used.
2024-08-12 9:27 AM
Hi @MasCreyt21 ,
Without more information on where you've been unsuccessful, I will try to explain all steps.
So, assuming you've had positive communications with the IC (read/write registers, etc):
1. Start by setting up the Performance/ Power Mode you want:
case XL_Power_Mode_ODR::Mode_High_Performance_6_66_kHz:
WriteRegisterBitRange(LSM6DSOX_CTRL1_XL, 7, 4, 0b1010 );
WriteRegisterBit ( LSM6DSOX_CTRL5_C, 7, false ); //XL_ULP_Enable
WriteRegisterBit ( LSM6DSOX_CTRL6_C, 4, false ); //XL_HM_Mode
break;
2. Set up FIFO:
void LSM6DSOX_::setFifo_Steps(){
WriteRegister ( LSM6DSOX_FUNC_CFG_ACCESS, 0x80 ); //Open Embedded Functions
WriteRegisterBit( LSM6DSOX_EMB_FUNC_EN_A, 3, true ); //Enable Pedometer sensor in Adv Func
WriteRegister ( LSM6DSOX_EMB_FUNC_EN_B, 0x10); //Enable false positive rejection
WriteRegisterBit( LSM6DSOX_EMB_FUNC_FIFO_CFG, 6, true ); //Enable Step Counter Batching
WriteRegister ( LSM6DSOX_FUNC_CFG_ACCESS, 0x00); //Close Embedded Functions
WriteRegisterBitRange( LSM6DSOX_FIFO_CTRL4, 2, 0, 0b001 ); //set FIFO Mode
3. Read FIFO Registers:
uint8_t reg1 = LSM6DSOX.ReadRegister(LSM6DSOX_FIFO_STATUS1);
Serial.print("FIFO Status 1: ");
Serial.println( reg1 );
uint8_t reg2 = LSM6DSOX.ReadRegister(LSM6DSOX_FIFO_STATUS2);
Serial.print("FIFO Status 2: ");
Serial.println( reg2 );
4. Clear FIFO at the end:
void LSM6DSOX_::setFifo_Clear(){
WriteRegisterBitRange( LSM6DSOX_FIFO_CTRL4, 2, 0, 0b000);
Sadly not able to share the project, but hopefully this helps.
Cheers,
Ben
Screenshot from the closed thread mentioned by @Andrew Neil (Credit to @Federica Bossi) :
2024-08-12 7:29 AM
@MasCreyt21 wrote:Hi BenG142
@BenG142 's thread was closed over a year ago:
https://community.st.com/t5/mems-sensors/lsm6dso-fifo-pedometer/td-p/61470
@MasCreyt21 wrote:I'm trying to develop a pedometer application using the LSM6DSOX sensor, but I haven't been successful.
So tell us what you did, and why you consider that "unsuccessful"
Did you follow the steps give by Ben and @Federica Bossi in the previous thread?
Please see the Posting Tips:
2024-08-12 9:27 AM
Hi @MasCreyt21 ,
break;
2. Set up FIFO:
Cheers,
Ben
2024-08-19 3:23 AM
@BenG142
Thank you for your help, BenG142. Thanks to you, I solved my problem, and the LSM6DSOX is working as I wanted.
