I3G4250 Not Updating Data At The Right Rate
I am using a I3G4250 on a custom PCB over I2C. When you first take data from it on restart it works but then after less than a second, it stops getting new data. It receives data exactly 25 times before stopping and sometimes receives about the same amount of packets more than 1 minute after.
Any help is appreciated,
Delta Space Technologies
Federica Bossi
Hi @deltaspacetechnologies ,
Welcome to ST Community!
Can you share your schematic? And also a reg dump to check if your writings are ok.
1 REPLY 1
Federica Bossi
