potting BLUENRG-M2SP and BLUENRG-M2SA
ljm
I hope you are well.
I am using your bluetooth modules with chip antenna “BLUENRG-M2SA” and PCB antenna “BLUENRG-M2SP”.
I'm going to put the 2 modules in the potting ? is there an influence of potting on the characteristics (range, transmission, power ...) of the chip and PCB antennas ?
What is the best antenna type and the least influenced by potting?
Thanks in advance
Have you asked the supplier of your potting material?
You'd want to know its properties at 2.4GHz ...
Hello
thank you for replying
I haven't chosen the potting yet, which is why I asked you.
Please, what are the potting parameters that can influence the antenna?
is the chip antenna better than the PCB antenna in potting?
Thanks in advance
