VL53L5CX Calibration after cover glass
MasterNi
Hi, I have two VL53L5CX and use glass to cover them. We can call them A&B.
To A, I use the VL53L5CX_XTalkCalibration   function after init.
To B, I do nothing.
But result of both are close. Does it mean I can cover the glass without calibration?
@John E KVAM@Anne BIGOT,
Anne BIGOT
Indeed this could happen when you have a good quality cover glass. The cross-talk is so low that calibration is not needed.
In your case with this cover glass, you can forget the calibration but keep in mind that with another cover glass, calibration could be mandatory.
Anne
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
1 REPLY 1
Anne BIGOT
Anne
