Resolved! Modifying I2C speed in X Cube TOF1 for VL53L1
HI,I am working on VL53L1 sensor using X CUBE TOF1 software. I want to change the I2C speed to 1MHz. Can somebody guide me how to do it?Thank you
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
Hi all,For the last several days I have been battling this API for the VL53L5CX and finally reached the point where the initialisation passes every time. I proceed to set some of the configuration parameters (mostly resetting to the default values su...
I've tried to use VL53L0X API, but it is too confusing. The API package STSW-IMG005 lacks any proper guidelines how to use API. The source file vl53l0x_platform results in one or another error.i'm unable to my own code VL53L0X as register map is not ...
I need to reduce the RAM requirement to use the VL53L8CX with a STM32WL55 application. I am working with STM32duino implementation and need an example of how to implement disabling some of the data output by the VL53L8CX (e.g. motion indication, mul...
Hi, We recently purchased few VD55G1 camera sensors along with Camera EVK kit and breakout board for Raspberry Pi. I intend to use it with Ambig Microcontroller. I downloaded Brighsense EVK software kit to figure out settings. I am referring to file ...
I put a object at about 1100mm, and another object at about 50mm. And use example5 to test vl53l7ch (4x4 resolution, max 2 objects per zone), but found that it does not recognise the closest object. For example, zone 13 output:[Zone13] (found 1 objec...
This is my first time posting.Thank you for viewing. ・I would like to use the VL53L5A1 sensor with the STM32L0 series.・Created according to the manufacturer's document "UM2974".・When I created it with STM32CubeMX Ver6.11.0, the build did not pass. Th...
Hi,I am testing VL53L8A with NUCLEO-F401RE and 53L8A1_SimpleRanging software under STM32CubeIDE.Changing RANGING_FREQUENCY from 5U to 15U does not increase the frame rate, always 5Hz.What am I doing wrong? I have changed also the TIMING_BUDGET to 5U ...
Hi,Can somebody please suggest me a ToF sensor with signal sampling rate of atleast 1MhZ. Thank you
Hello,I am using a VL53L8CX sensor in 8x8 mode. There is a thing that is unclear to me from the documentation, so I need a clarification. A value in the zone Z of the matrix I get from the ToF sensor is:a) Distance between the object in the zone Z an...
