Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
Question regarding VL53L1X_StopRanging()
According to the VL53L1X ULD API description when Vl53L1X_StopRanging() is called, an active ranging operation will be completed.In a practical evaluation we tried to investigate whether an interrupt could still occur after calling this function or n...
mf101 by Associate II
  • 1537 Views
  • 4 replies
Evaluating the quality of a cover window by measuring crosstalk
In the production process of a product using the VL53L1X TOF sensor we would like to evaluate the quality of the custom assembled window. There are some mechanical tolerances and we need to ensure that the crosstalk is as low as possible. Is there a...
  • 1204 Views
Resolved! VL53L1 and VL53L3CX not found in i2C Scan
Hi thereI can't find out how to connect my sensor to an arduino uno. Tried both with sample codes from SparkFun and i2C example code. It is connected in the following way:SCL -> SCLSDA -> SDAGND -> GNDVDD -> 5VI also tried with 2K ohm pull-up resisto...
MTjel.1 by Associate II
  • 4801 Views
  • 9 replies
