VL53L5CX TOF
  • March 28, 2024
  • 1509 views
Hi Team,
We have our customized projector majorly focused on educational field purpose.
Its a short through projector with 16:9 aspect ratio.
We are planning to implement Auto keystone and Auto Focus using VL53L5CX TOF sensor.
Do you have any driver support for this particular implementation.??
Any Knowledge article related to this implementation??
Thanks & Regards
Deep_Bang
Best answer by John E KVAM
Deep_Bang -
We have a team in Asia that supports our projector business.
In theory you do not have to do much, although I would suggest using the VL53L8. (Better sensor, same price.)
You are going to get either an 8x8 group of distances or a 4x4 group.
If you point the sensor perpendicular to a flat wall all the numbers will be very close to each other.
Tilt it up and the distances on the top numbers will be more than the bottom row.
From there it's just geometry. Although I'm sure our team will do a better job of describing it.
- john
John E KVAM
John E KVAMBest answer
Deep_Bang -
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
Anne BIGOT
Hello
We propose a package on st.com for keystone projection with VL53L1. It is here.
Anne
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
