Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
How to interface the VL53L3CX with an ESP32
Hello, I am trying to connect a VL53L3CX (a module I purchased on AliExpress) with the ESP32. I have found the Arduino library but it does not fit the ESP32. I will highly appreciate your help in helping me get this working. Thanks a lot, Motti
MBaza.1 by Associate II
  • 6030 Views
  • 3 replies
VL53L1CB Low Ranging Performance and Flickering
Hi,I designed a sensor array containing multiple VL53L1CB sensors. They are configured to scan a 3x3 grid inside its view with multizone scanning. That works great at small distances but suffer a distances above ~1,5m.Experimentation shows that the s...
dlux by Associate II
  • 6041 Views
  • 12 replies
Resolved! Printing Garbage Value
Hi there,I am working with tfmini lidar and i am using USART3.However i am getting the garbage in the virtual port any idea how can i resolve this but i am getting the right header i.e YY in decimal. Any suggestion would be appreciated.Thanks
VL53L1X outdoors
The VL53L1X outdoor performance is hindered by huge amounts of noise, and wildly fluctuating results, compared to indoors. I notice that the demos I can find online about this sensor conveniently never show it outdoors, although some articles mention...
MWatt.2 by Associate
  • 10737 Views
  • 8 replies
  • 1 kudos
VL53L1 TOF sensor: We use the VL53L1CBV0FY/1 sensor. 1. What is the cleaning protocol if dust gets on to the sensor? 2. Is this sensor available with dark protective film to enable easy detection and removal of the same during use?
We have sensors failing because of what looks like dust or debris that is getting on the sensor. Also, often it is difficult to detect and remove the Kapton tape covering the sensors. The tests we run pass even though the film has not been removed so...
GRavi.1 by Associate II
  • 2846 Views
  • 4 replies
