Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
Interrupt reset on e.g VL6180X
I want to use the TOF unit to detect when a physical object is passing. The Threshold detection shall rise an interrupt signal which I use to initiate a function. As I understand the mentioned VL6180X, the interrupt must be cleared each time via a...
PThom.3 by Associate
  • 1574 Views
Minimum consumption Vl53L3x
Hi, I plan to use the VL53L3:The goal is to power it with 1300mah battery, 200ms measurement refresh rate, 2 years life expectancy. The product could reach <100µA in this conditions ?Thanks
JDUBE.1 by Associate
  • 909 Views
  • 1 replies
VL53L3CX Bare Driver on Raspberry Pi?
Hi, I'm trying to get the bare driver running in user mode to work on the Pi, because I just need the easiest way to use the VL53L3CX module, and I think the Linux driver is not necessary. I'm not sure how exactly to get the ULD working on a Pi howev...
VBhat.1 by Associate III
  • 1507 Views
  • 1 replies
  • 1 kudos
