Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
How to set 2V8 power mode with VL53L1X ULD API
Dear Sir,We connect VL53L1X to our host that provide 3.3V VDDIO. We will use VL53L1X ULD API as driver for our system. By check VL53L1X ULD API code, I can not find code about setting power mode to 2V8. Would you like to give any information for thi...
DSai.1 by Associate III
  • 1578 Views
Operating condition about AVDD of VL53L1X
We use VL53L1X for our product development. Based on the datasheet, the typical operating condition for AVDD is 2.8V. I wonder if we can use a 3.2V for AVDD? If 3.2Vis provided for AVDD, is there any problem that may affect the performance of VL53L1X...
  • 1602 Views
  • 3 replies
about ApiExample in STSW-IMG007
Dear Sir,We are going to port VL53L1X API driver to our threadX environment.We download the en.STSW-IMG007.zip and a document stsw-img007.pdf.The document of API described that there are Api, ApiExample and doc in this package, but there are only A...
  • 1379 Views
Can't switch VL53L1 and VL53L1x sensors into threshold mode.
Dear Sirs, I have some problems with VL53L1 and VL53L1X sensors which i'm using in my project.Now i'm trying to figure out how to switch them to different modes and apply different settings in accordance with API manuals and datasheets. I'm also usin...
DBlok.1 by Associate
  • 3597 Views
  • 4 replies
How to determine what ToF chips are attached to a board?
Identifying TOF chips in a system... Is there a way to determine what chips are attached to a board? We would like to support multiple TOF parts, but need to know what parts are attached to the I2C bus before writing to them.
JMerk.1 by Associate II
  • 1916 Views
  • 3 replies
Is my calibration environment good enough?
Hi there,Following this topic, I've made a box out of black paper, perhaps it work for calibrating xTalk.We couldn't get the customized paper, but here's the box with side's distance = 25cm.    The results of both offset and xTalk are inconsistent, g...
0693W00000QMx61QAD.jpg 0693W00000QMx6QQAT.jpg 0693W00000QMx7OQAT.jpg 0693W00000QMx7dQAD.jpg
HHaje.1 by Associate II
  • 2269 Views
  • 3 replies
