2023-12-04 12:47 AM
How to know the TESEO VIC3DA module work correctly in designed board ?
Thank you very much
2023-12-06 1:43 AM
Hi
1. You should have NMEA stream on the UART
2. in the $xxGSV you should have consistent data (to check RF-path)
3. the board should be strongly fixed to the car
4. after 10 minutes driving (time to calibrate) your VIC will be fully calibrated
2023-12-06 1:43 AM
Hi
2023-12-06 1:49 AM
thank you very much
