2023-11-06 10:42 PM
Hi Team,
In this module(TESEO-LIV4f) can able to processing the data L5 band(NACIC data and IRNSS)
And how to update the firmware for l5 band(navic and Irnss) and pls give refrence.
And any break out board avaliavle for this module(TESEO-LIV4F)?
Thanks and regards
ARavind.S.R
2023-11-08 02:37 AM
Hi
End of this years (early next year) there will available:
- X-NUCLEO-LIV4A1 (arduino form-factor)
- X-STM32MP-GNSS2 (raspberry form-factor)
Francesco
2023-11-06 11:54 PM
Hi
Teseo-LIV4F can support IRNSS (with other constellation) using a dedicated firmware (firmware available in the Teseo-LIV4FSW page). You can install it using the standard firmware upgrade procedure (or the teseo-suite).
End of the years or early next years two new prototyping board with Teseo-LIV4F will be available.
Francesco
2023-11-07 08:33 PM
Hi Francesco,
In this module (Teseo-LIV3FL low power GNSS module evaluation board) can support Navic signal.
https://www.mouser.in/ProductDetail/STMicroelectronics/EVB-LIV3FL?qs=TuK3vfAjtkUQ7PYXAmUrgA%3D%3D
Thanks and Regards,
Aravind.SR
2023-11-08 12:55 AM
Hi
Sorry but all the LIV3 module family are L1-only GNSS, they can not acquire IRNSS because IRNSS sits on L5 signal.
At the moment Teseo-LIV4F is the only ST module able to acquire IRNSS
Francesco
2023-11-08 01:50 AM
Hi Francesco,
Thank for your response!
Any evaluation board avaliable for this module(Teseo-LIV4F)?
Thanks and Regards,
Aravind
2023-11-08 02:37 AM
Hi
Francesco
2024-01-16 07:40 AM
Future Electronics have this one that have the LIV4F
https://www.futureelectronics.com/future-development-boards/vespucci-evaluation-board
