GNSS positioning
Ask questions and find answers on Teseo GNSS positioning solutions. Discuss NMEA sentences, SBAS activation, and signal troubleshooting.
Teseo-VIC3D
HiI have some question regarding the Teseo-VIC3D information which I cannot find.1. The Teseo-VIC3D should have its own asm330 unit which internally is interfaced over SPI, right? 2. Is it possible to interface the ASM330 as if it where an external h...
TESEO-VIC3A No more responding after manual configuration
Hi all,I have been using the TESET-VIC3  to test IMU sensor, I enable SENMSG from message list 0 ($PSTMSETPAR,1228,0x7********) I found that latency is so High when I receive $PSTMSENMSG,30/31 So I chose to disable all GNSS-related msg and keep only ...
Rihdan by Associate
  • 2379 Views
  • 3 replies
Resolved! Teseo-VIC3DA dead reckoning mode
Hi,I bought a Teseo-VIC3DA Evaluation Kit and when I went through the associated documents, they mentioned the concepts of "Teseo-DRAW and Teseo-DRUM". In my application, we do not have access to the vehicle's wheelticks/direction information so I gu...
Fan1 by Associate III
  • 14452 Views
  • 18 replies
  • 1 kudos
Resolved! Teseo-Suite activation
HelloI need to use full featured Teseo-Suite.Sending letters to st-teseo-suite-support@st.com remain unanswered.How could I obtain a full version of Teseo-Suite?Thanks
ASamo.2 by Associate II
  • 6130 Views
  • 8 replies
  • 3 kudos
TESEO-VIC3D electrical specs missing from datasheet
Hi the Teseo VIC3D datasheet doesn't seem to have very detailed electrical specs and neither does the UM2832 hardware manual. I assume the gpio are push pull referenced to VCC. I'm looking for VIH, VIL, VOH, VOL, any power on or sequencing requiremen...
Teseo-LIV4F Hot Start
Hello, I am a newbie on GNSS modules, trying to understand behavior of module. I look at Software Manual and all the commands, PSTMHOT, PSTMWARM, PSTMCOLD command get my attention. When we use these set of commands ?For example I have teseo module wi...
KOzdi by Associate II
  • 3159 Views
  • 3 replies
Resolved! Teseo VID3DA imu fusion level
Hi I'm now using Teseo-VIC3DA through evb.I have a curiosity about which level the sensor fusion btw GNSS and IMU is performed.I can log the data through Teseo suite application.But i can't figure out that GNSS messages such as NMEA GNGGA, GPVTG etc....
engson07 by Associate II
  • 3876 Views
  • 5 replies
