GNSS positioning
Resolved! TESEO VIC3DA
Hi,How to know the TESEO VIC3DA module work correctly in designed board ?Thank you very much
TESEO VIC3DA
Hi,I am new in TESEO VIC3DA. I have designed a board communication between MCU and TESEO VIC3DA.Does TESEO VIC3DA auto send NMEA sentences to my MCU through uart peripheral ? Thanks
Resolved! Teseo LIV4F output data rate configuration
Hi all,I have been doing some experimentation with a LIV4F module and am trying to configure the device for a 5Hz data output rate. I see the device supports up to 10Hz.The commands I have tried via teseo suite are:$PSTMSETPAR,1190,0.2 followed by $P...
AlexT by Associate II
  • 2662 Views
  • 4 replies
  • 3 kudos
Teseo-LIV4F
Hi team,    I already have this module-Teseo-LIV3F( https://estore.st.com/en/evb-liv3f-cpn.html ) But i need communicat the L5 band NAVIC signal. In this module not supported the L5 NAVIC signal.In this module-Teseo-LIV3F( https://estore.st.com/en/ev...
Aravind by Associate III
  • 3162 Views
  • 7 replies
  • 1 kudos
Firmware update for IRNSS,Teseo-LIV4F
Hi team ,     How to configer the firmware update for IRNSS and how to create a binary file.Firmware update which software is using?and any breakout board avaliable (Teseo-LIV4F) Thanks and regards Aravind
  • 906 Views
  • 1 replies
Resolved! Using A-GNSS to improve TTFF
Hello I am interested at looking at the Teseoo-LIV3F for a application but I require a very fast TTFF. Having read up on the A-GNSS option will this be available any where or any location in the world as long as the server is accessible ?So no matter...
