Andrew Neil
Unmark Solution is too hard to find
mƎALLEm
On other forums, the 'Mark As Solution' just changes to 'Unmark Solution' (or whatever) - so it's always
Do you mean a button that toggles between two status: "Solution" / "Unmark Solution"?
Andrew Neil
Yes. :thumbs_up:
mƎALLEm
Indeed.. it does make sense!
Lina_DABASINSKAITE
ST Community Manager
February 28, 2024
Thanks @Andrew Neil for bringing this up!
I have added the respective comment in the guidelines about the "Not the Solution": Help others to solve their issues - STMicroelectronics Community
Meanwhile, I will check if and how we can modify this button to be more intuitive. Will keep you posted once will have more news.
Lina
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Visitor II
March 6, 2024
Thank you so much for the link.
Andrew Neil
This seems to apply generally to items on that menu; eg,
https://community.st.com/t5/feedback-forum/how-to-edit-a-post-is-too-hard-to-find/m-p/665292#M1304
ie, it's that whole menu which is Too Hard To Find - the tiny little button is too obscure!
Andrew Neil
Andrew Neil
Andrew Neil
Andrew Neil
Andrew Neil
Andrew Neil
Andrew Neil
