AlgoBuilder for STEVAL-MKI109V3 hardware?
FKara.3
Does the AlgoBuiler GUI support STEVAL-MKI109V3 hardware?
3 REPLIES 3
Guru
Not directly, as it's not on the list of supported devices.
You could support it by using a custom board template as described here:
For custom hardware it is necessary to create an AlgoBuilder firmware template using STM32CubeMX and X-CUBE-ALGOBUILD extension.
https://community.st.com/t5/mems-sensors/what-other-hardware-can-be-used-as-a-target-for-algobuilder-gui/td-p/304736
Thank you for your quick response. I followed the instructions in the document However, the board STEVAL-MKI109V3 has not been added to the system. as you can see below picture.
Guru
@Evelina CAMILLERI Ideas?
