Can i use multiple sensors of the same type simultaneously to improve measurement quality?
‎2024-05-23 1:25 AM
My question is, using Algobuilder (or mems studio) and unicleo, can i use for example two accelerometers (on hardware nucleo 401RE, x-nucleo ISK01A3 and steval MKI233) and get data from them simultaneously to reduce the measurement error/noise?
Whats the best option for this to be made?
Thanks in advance
‎2024-05-28 6:21 AM
Hi @aesteban ,
Welcome to ST Community!
Unfortunately, this is not possible in AlgoBuilder or any other FW.
A solution you could try is to generate Datalogterminal firmware using CubeMX and X-CUBE-MEMS1 package. But it will send the data to terminal.
‎2024-05-28 6:21 AM
Hi @aesteban ,
