Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
eirq interrupt
Hi, can anyone share to me the code for push button that using eirq interrupt? I do see on the example and also successfully build with no error. But when i debug and try to my hardware, nothing happened. LED do not blink when i click on push button
Angle by Associate II
  • 1155 Views
  • 1 replies
1. to make non cache area in the SPC58NH, making memory attribute to Cache-inhibit is right? 2. what is difference between data descriptors and shared descriptors? 3.The SPC58NH does not support write-through attribute for cache? if can how?
1. to make non cache area in the SPC58NH, making memory attribute to Cache-inhibit is right?2. what is difference between data descriptors and shared descriptors?3.The SPC58NH does not support write-through attribute for cache? if can how?
Calculating faster
Hello,​ I'm working with spc560p and I want to calculate my code my code more faster as usual. I Impelement PIT DRIVER too for other use of my mcu. Is there any method to calculating faster?​Thanks for your attention
DNewm.1 by Associate III
  • 1380 Views
  • 1 replies
Sensor Driver
Hi, can i know which driver use for displacement sensor? and also can i know which one is the example code for the sensor so that i can refer
  • 868 Views
  • 0 replies
