Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
SPC560 - eMIOS
Posted on August 20, 2015 at 18:04Hello,I am using eMIOS module for SPC560D40L3 MCU for generating PWM. I am using default configuration for the SPCStudio project with no change to FMPLL0 and Clocks settings. My target uses 8MHz external XTAL. With ...
ssk by Associate II
  • 1602 Views
  • 3 replies
SPC560 - SWT
Posted on August 12, 2015 at 15:03Hello,I am using software watchdog timer (SWT) for the SPC560D40 MCU. What is the 'out of reset' situation for the SWT?Best Regards,Mike. #swt
ssk by Associate II
  • 1906 Views
  • 5 replies
Problem with Lin Enable filters
Posted on August 12, 2015 at 11:01Hi I Have 2 problems with Lin : 1.When i Recive a data from LIN I have  No interrupt  2.When i want to set a filter in LIN the programm not work at this point in the attachment code :LINFLEX_1.IFMR.B.IFM=1; LINFLEX...
Licence Problem for SPC56_DRV_LIN2.1-0.9.5 Lin Driver
Posted on August 04, 2015 at 17:45Hi I Download this software for using Lin Driver on SPCStudio But When you want to setup this software , the software need a serial number but i send request to apg tools but have no response for my request. i wan...
Bug On SPC560B50L5 UART Mode in SPC Studio
Posted on August 04, 2015 at 17:40Hi I Want to Use LINFELX2 in uart mode in SPC560B50L5 but in HAL Driver Component Have 2 LINFLEX (LINFLEX0 and LINFLEX1) there is not exist LINFLEX2 OR 3 !!!! Are Those driver's not supported or i can not use this ...
SPC560P TSENS corresponding to the voltage
Posted on December 04, 2014 at 04:37Hi, Anybody can give me the table about the SPC560P sampling temperature corresponding to voltage? Best regards Liu Wei #internal-temperature-sensor
How use ICU driver?
Posted on July 07, 2015 at 20:22 Hello, I have to simulate the behavior of this function Arduino on Chibios for the management of my sensor. duration = pulseIn(ECHO_PIN,HIGH); I use ICU driver to detect the rising and falling ...
gl2 by Associate III
  • 4182 Views
  • 7 replies
SPC56EL60L5CBF ECC Error
Posted on July 10, 2015 at 11:24Hi, Recently we received few returns from customer with ECU entering Error Mode. The only information we have for now is values of registers in time of exeption: 00000020 - ESR        - VLEMI (VLE Mode Instruction) 00...
dariusz by Associate II
  • 2335 Views
  • 4 replies
Using standard header files
Posted on April 22, 2015 at 11:47I am trying to use standard header files - string.h, stdint.h with SPC5Studio. When included to the project, it displays a message as 'unresolved inclusion <string.h>'. What can be done to resolve this? Whether SPC5S...
ssk by Associate II
  • 6501 Views
  • 16 replies
