Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! Missing pal_lld.h in MCTK Lib on SPC5 Studio 6.0.0
Good day,I might be missing something, but an issue cropped up when I moved to SPC5 Studio 6.0.0 Asimov when attempting to compile any project that includes the MCTK Web Library. The message that I get while building is:./components/spc56xx_web_motor...
PMoll.1 by Associate
  • 1517 Views
  • 1 replies
Resolved! About the PWM minimum duty cycle time in SPC58EC
Hello!​I have a SPC58EC-DISP; I set the PWM frequency 20KHz and duty cycle 1%,then it's not output,when set 8%,it's output 2us time;I found that the minimum PWM output time seems to be 2us.now I want PWM frequency 20KHz(50us) and 1%(0.5us) ouput,wh...
SLEE.6 by Associate II
  • 1918 Views
Resolved! CAN setup in SPC570S-DISP dev board
Hi,I am trying to setup CAN communication in the SPC570S-DISP dev board. I started with the example available in the SPC5Studio. In the example, internal loopback is enabled, so I disabled it to allow external transmit. I did not change any other set...
NBula.1 by Associate III
  • 2123 Views
  • 4 replies
  • 3 kudos
Resolved! Flash test application and bootloader for SPC584B70E5 discovery
Hi, Can someone guide me on where I can find the sample Flash test application and bootloader application for SPC584B70E5 discovery.I searched in import wizard of spcStudio but didnt find any.Thanks in advance. Flash test applications are available f...
CJadh by Associate II
  • 1896 Views
  • 3 replies
Resolved! PLS UDE Debugger does not change the value of global variables
Hello,I wrote some codes and it worked succesfully. Then I wanted to add some global variable for computing a value but global variables which are added later, their values did not change, altough I set the refresh period setting ( while are changing...
Msert.1 by Associate III
  • 1714 Views
  • 1 replies
Resolved! How to measure the stack remaining available size
I had to enhance the stack size using __process_stack_size__ value to make my software running and I would like to know how to measure the stack remaining size. I tried commenting out the ram init in boot.s and fill the stack ram area with a 0x55AA p...
