Frozen ADC Bits in Debug Mode
‎2020-11-17 2:46 AM
How can I watch the values of global or static variables for ADC Module. When I add the variables which keeps data to the watch table, I dont see what's going on. They don't change. ( Also I wanna learn this for Timer and other Modules)
‎2020-11-19 6:47 AM
I presume you are using PLS UDE STK debugger.
- Select the Watches window
- Right click on the variable to watch
- Select Refresh Period
- Enable refresh on Running target
- Set the preferred refresh period (in milliseconds)
Giuseppe
‎2020-11-19 6:47 AM
Giuseppe
‎2020-11-19 11:22 PM
Thanks, I use PLS UDE. And other question, what are the most used debuggers for automotive application?
‎2020-11-30 12:19 AM
from what I know, most used debugger for automotive applications are:
- PLS (https://www.pls-mc.com/)
- Lauterbach (https://www.lauterbach.com/frames.html?home.html)
- iSystem (https://www.isystem.com/)
or visit our Partner page:
https://www.st.com/content/st_com/en/partner/partner-program.html#2
Giuseppe
