2016-03-14 11:58 AM
I'm trying to set up a STA311B to send an I2S signal to a DAC. Do you have any sample schematics? My main question is which chip should provide the MCLK signal to the DAC.Also, is it documented what would be the minimum delay introduced if I connect my source to an input in the STA311B and then route it through it to the DAC?As always, thanks for your help.Jorge Rivera #sta311b2016-03-14 7:44 PM
2016-03-17 1:50 PM
