Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
Questions about TDA7293
Posted on June 02, 2016 at 07:54Dear Support Team, I am using the TDA7293 as per datasheet recommendations. I am also using the MUTE and STBY pins but not the CLIP-DET pin. Everything is working without any issues. My question is: 1. Can I connect ...
ravindra by Associate II
  • 1337 Views
  • 1 replies
STA 326 gain setting
Posted on May 23, 2016 at 00:26Is it possible to change the gain setting?Hardware or software?Have problem with noise in low level listening-desktop.
solveit by Associate
  • 908 Views
  • 1 replies
TDA7384A: Sink size, power dissipation and load
Posted on July 31, 2015 at 18:58Hello,I'm modifying a device that no works very well. This device includes one amplifier TDA7384A, and in the old design I found several mistakes or parameters that haven't calculated. I saw the datasheet and i didn't...
cperuj23 by Associate II
  • 2545 Views
  • 8 replies
STA311B Mix#1 Issues
Posted on April 04, 2016 at 16:53On power up, I want to be able to initialize various registers and also the coefficient RAM to set things like the MIX#1 coefficients, however I found something strange.When the STA311B is released from reset (RESET ...
sethier by Associate
  • 1924 Views
  • 3 replies
STA311B - RESET pin behavior
Posted on April 05, 2016 at 18:58Hello, Does the RESET pin have an internal pull-up? It seems that there's always ''0'' on RESET pin when it's floating on my STA311B... And it sinks up to 15 mA when I'm trying to pull it up to VCC with external res...
spam9986 by Associate
  • 1320 Views
  • 1 replies
STL62P3LLH6 Safe Operating Area correct?
Posted on March 30, 2016 at 18:19I'd like to know if the STL62P3LLH6 P-channel MOSFET's Safe Operating Area chart is correct in http://www.st.com/web/en/resource/technical/document/datasheet/DM00105886.pdf. I have been comparing these charts of vari...
STA321MPL : changed in new IC's version?
Posted on March 24, 2016 at 14:01I bought STA321MPL 2 times: 1st times with the label on chip:  ''9912D VJ MYS 11 237 ''                                                2nd times with the label on chip:  ''990R4 VJ MYS 99 532''Unfortunately, all STA3...
son1 by Associate II
  • 7863 Views
  • 11 replies
STA311B - I2S out not working
Posted on February 29, 2016 at 22:26Hello,I am testing a new STA311 design and I cannot get I2S output from the IC. I have I2S input running at 48kHz with BCK, LRCK and System clock (12.288MHz) present (coming from an ADC). I2S output is enabled but...
jeliazkob by Associate II
  • 1609 Views
  • 5 replies
Clock circuit for STA311B I2S output - and minimum delay
Posted on March 14, 2016 at 19:58Hello,I'm trying to set up a STA311B to send an I2S signal to a DAC. Do you have any sample schematics? My main question is which chip should provide the MCLK signal to the DAC.Also, is it documented what would be th...
jorge by Associate II
  • 867 Views
Reliability
Posted on March 03, 2016 at 20:09Hi, How can I get TSC101 current sensor failure rate or FIT?
