2019-04-12 6:00 AM
Hi, I have installed STM32CubeProgrammer but unable to run it. I get the message:
"CubeProgrammer_API or one of its dependencies is missing. Please try reinstalling the program of check your java architecture"
I see other have had this and upgrading to the latest version, or running as administrator has worked for them.
I am using V2.0.0 and I get this message whether I run as administrator or not. Is there anything further I can do to debug why this is not running?
For reference, Windows 10 Enterprise 2016 LTSB 14393.2848.
Java V8 Update 201 (build 1.8.0_201-b09)
Thanks, Mark
2019-04-12 6:04 AM
Solved by running the installer again but this time running the installer itself as administrator.
Hope this helps someone else!
2019-04-12 6:04 AM
