2019-05-14 8:56 AM
We are trying to use STM32CubeProgrammer on Windows computers running JDK 11 and higher. Is this not supported by CubeProgrammer? It does not appear that the program contains the typical BIN file that we would edit to use a different version of Java installed on the machine. Is there any other option than having to use JDK8 as the main Java install?
2019-05-24 3:26 AM
Hello @jw56 ,
Yes JDK11 is not supported by STM32CubeProgrammer, you shoul install JDK8/oracle JRE8.
Houda
2019-05-24 3:26 AM
Hello @jw56 ,
Houda
