I used STM32CubeProgrammer v2.1.0 in utuntu 18.04. Connect STM32F103ZET6 failed. Usb to serial port is WCH CH340G.
Options
2019-05-22 11:20 PM
13:05:04 : Serial Port ttyUSB0 is successfully opened.
13:05:04 : Port configuration: parity = even, baudrate = 115200, data-bit = 8, stop-bit = 1.0, flow-control = off
13:05:05 : Timeout error occured while waiting for acknowledgement.
13:05:05 : Error: Activating device: KO. Please, verify the boot mode configuration and check the serial port configuration. Reset your device then try again...
Labels:
- Labels:
STM32CubeProgrammer
STM32F1 Series
0 REPLIES 0
