2024-11-27 04:47 AM
Hi!
I wanted to ask the following: Is it possible to get the output of STM32_Programmer_CLI.exe as JSON?
We use the CLI within one of our internal software tools and the parsing of the output is a little brittle. A structured output format would help a lot. As far as I have seen, the CLI does not support JSON output right now. Is this correct?
Thanks,
Christian
2024-12-11 06:58 AM
Hello @ckrenslehner,
Yes, you are correct. Could you provide more details on the specific information you would like to get as JSON, for example are you looking for the JSON to include the Option bytes display, memory data or all the CLI output as it does the command '-log' but in JSON format?
Thanks,
Amine.
