I am working on a STM 32 project in which at debugging step I found error thatis
Error: The download command you trying to perform (--download) is missing the filePath to be loaded or it has a wrong extension Error in STM32CubeProgrammer
Shutting down
‎2022-09-09 3:54 AM
‎2022-09-14 9:46 PM
@MM..1​ and @Semer CHERNI​ Thank you for your help. Now I have resolve the issue it is because of the special character(&) is present in the directory path of the workspace So due to this program is not debugging Now i have changed the directory for workspace.
Hope it will helpful for others.
‎2022-09-09 8:20 AM
And ??
Create Simple thread name and details ...
‎2022-09-09 12:12 PM
Without some kind of command line to look at, or some context, these types of questions are hard to resolve.
Make a better presentation.
‎2022-09-09 9:25 PM
@Community member​ and @MM..1​ I have attached the image of the dialogue box showing the error. Again I have tried but the same error occurred. Please help me.
‎2022-09-10 2:25 AM
Still hard to help, maybe incomplete debug configuration, maybe long project path or folder names with spaces or special chars usw.
‎2022-09-10 2:48 AM
I have also made a new project with this name and deleted the old one copied all files and folders but still showing this error.
‎2022-09-10 2:58 AM
Try show screen debug config , on your shot i see used \\ \\ path , from where is your project git? On example
‎2022-09-10 4:08 AM
@MM..1​ This is the debug config screenshot.
‎2022-09-10 7:55 AM
Try load builded ELF externaly over stlink utility or proggrammer. If works, seems your IDE install is incomplete or corrupt, try reinstall.
‎2022-09-13 8:36 AM
Hello @SGoel.2​
As mentioned by @MM..1​ try to use CubeProgrammer to flash the binary. That result of this test could help to identify if it is a debugger issue or Programmer issue.
Also I want to ask you to post the rest of the debug configuration and try to generate and send post the debug log so I can analyze it.
You can do that by checking the box "log to file" under the debugger configuration window.
Kind regards,
Semer.
